Need help to upgrade my current RAM
orhkia
Hi,
Any cheap and good recommendation on upgrade my RAM to 16gb
Current build is 2x4gb corsair vengence LPX 2400mhz
Not sure why when playing csgo my fps will drop a lot during smoke and flash so trying to upgrade RAM to see whether can resolve this issue
My current rig
Intel i5-7400 3Ghz
Asus H110M-A/M.2
2x4gb Corsair vengence LPX 2400mhz
Asus GTX1060 6gb DUAL
using a normal SSD to run csgo
I bought my processor, RAM & GPU last year.
Ferolare
Don't think adding more memory is the answer to smoke grenade tanking fps in csgo bah :crazy:
singupingu
Eeerrrr..... You can read reddit on this. Plenty of ppl complaining smokes causes fps drop. Nothing you can do really. Your gpu looks good, CSGO don't eat ram too, so 8 vs 16, I don't think it will solve your issue as this is likely due to gpu computing the transparency. Gpu will spike during smoke grenade scenes.
Easiest way to reduce the drop is reducing your AA, though at the cost of some screen tearing.
Sent from OnePlus ONEPLUS A3003 using GAGT
shadey
Contrary to the myths from the 1990s, more RAM will not help you here.
Your bottleneck is that you chose to save money on the 1060.
Good news is that 1070 and 1080 are available cheap cheap now.
Phen8210
lower the settings, upgrade gpu wont increase ur fps further since u already using 1060.
orhkia
my settings is the lowest already. im getting 200+ fps near 300dps but when smoke n flash it drop to 100+ n encountered spike and lag. i read some of the reddit it say csgo eat more processor and ram than GPU.
Godeau
Need 9900k and rtx 2080ti to play cs go.
Good news, they are around the corner :)
Phen8210
It doesn't really eat processor either. The game is not optimized for pushing high framerates and yet it is only enjoyable with it.
Higher single core performance will increase the fps in this title.
Kyo_kusanagi86
to play CS GO smoothly, you need a 1080 GTX , i7 processor and at least 16gb of ram. confirm no such lag.
Mine on a 980 GTX SLI lags when more people throw smoke. :(
in short time to upgrade~
