Need Help Unknown problem desktop
SlacKKing
Story:
He said he wanna reformat so i help him with the reformat
(After reformat then he tell this story)
The Friend said he heard a buzzing sound and the Pc hang.
He forced restart and then it Starts all the problem.
Installing clean Win 8 to a 5 yrs old deskop? It been using Same windows 8 from b4.
Install all the way normally till Windows show the "Getting Devices Ready..." highest percentage it go is 7%
After which the screen will blank off and switch back on but just Black screen. it is runing as the monitor nv says "Goes to sleep mode"
Wait 10 mins nothing Happen
During installing the screen no blank off what so ever.
1st i tot it was the SATA cable was faulty. Replace with another 1 in pc not in used same issue.
Swtich out the SSD to the HDD to install OS still same problem.
Any other way to remedy this issue.
radiobox
Remove graphic card and use 1ram. use a bootable usb Ubuntu or Linux mint to run. Check if it can run with USB Linux. Next install Linux only take 10-15min. Shutdown and add all ram and gpu. If it run than system OK. Install Windows if not update which part fail
yusoffb01
It can happen if ur using HDMI via Intel graphics.
Solution is to use VGA if using integrated, or use a graphics card
jtjt00
Suspect graphics card faulty, default windows generic driver is fine. The moment windows update start install the GPU driver, it kaput.
