Need help upgrading to current gen build
zenitro
Well long story short, my computer and me gave out on each other.
More details
http://forums.hardwarezone.com.sg/hardware-clinic-2/what-wrong-my-rig-5716473.html
Now, I am looking to make my next desktop and would like some advice regarding the parts as I am very very blur right now regarding such issues
I am not sure about current gen CPU and motherboard with the introduction of ryzen(is it better than intel?)
Main purposes of computer is web browsing and some gaming(no need to maxed graphic). (want to play monster hunter world when it come out^^)
Regarding CPU, I personally don't overclock as firstly I don't know how to and secondly I don't think I need to(not yet anyway)
Parts from my current desktop that should be reusable
GPU - ZOtac 1050
HDD - 1tb
PSU - Superflower 550v 80+ silver (sld i change?)
Corsair 300R case (Sld i look for another case? suggest one anyway if i got spare cash)
Budget around 500-800 hopefully as I know DDR4 price is .......
Pleas help ^^:D
dgenex
I3-8100 for budget
I5-8400/ Ryzen 5 1600 if u wanna fork out more
Do note that ryzen dun come with iGPU, meaning if ur GPU died then need get a new one, intel de have integrated graphics at least can use for basic usage while you source for new gpu or waiting for replacement
Psu use how long le? If many years can change liao ba.
Case can look at Phanteks P300 and fractal design stuff generally pretty good quality if ur looking for mATX size
Sent from Xiaomi MI A1 using GAGT
singupingu
Since you current pc already considered dead, if you can't wait much for cheaper B360 or H210 boards, then Ryzen is the way to go. Here's what I have in mind:
CHASSIS: *reuse*
MOBO+CPU: MSI B350M Mortar + AMD Ryzen 5 1600 $457 from PC Themes
RAM: Klevv Bolt4 3000MHz 8GB (2PCS-16GB) $258 from Tech Deals
PSU: *reuse*
SSD: PNY Phantom-1 240GB $119 from Lazada
HDD: *reuse*
GPU: *reuse*
OS: Windows 10 Home $12 from Carousell
TOTAL: $846
Sent from Finally Unbanned using GAGT
