need help upgrading!
vtecXx
hi guys,
I'm currently considering an upgrade of my system as its old (4years+) already. Would need your advise on the upgrades as i'm a tech noob. Have a budget of 1k. I use it mainly for gaming and entertainment purposes. Games i play are mainly FPS like call of duty, battlefield etc.
My current rig is:
intel i7 860 + msi p55gd 65
kingston 2gb ddr3 x 2 pcs
powercolour 5850 1GB graphics card
wd 1tb black hard disk
seasonic 500w psu
coolermaster haf 932 case
i already have a 256ssd yet to fix up so please exclude the ssd. My casing is also a bit dirty and the fans are a bit rusty already. don't know if i should change the case too. Please recommend bros!
many thanks in advance!! :)
royfrosty
For 1k the mobo cpu is fine. But if you really wanna upgrade then i would suggest a new mobo and cpu plus a 8gb of ram. Add in a good gpu.
Msi b85m g43 + i5-4570 ~ $347
Crucial 8gb 1600mhz ~ $89
Reuse hdd
Reuse ssd
Msi R9 280x twin frozr 3gb gaming ~ $459
Superflower hx600 600w 80+ gold ~ $108
Total ~ $1003. Buy at tradepac. Diy
Jian19
Still looks decent
Crucial 8gb ddr3 ~ $90
Msi 280x ~ $460
Superflower hx 600 ~ $109
$660 buy and DIY @ tradepac
Can buy a few new fans and do some cleaning of ur case and good to go ~
vtecXx
how come i see so many ppl recommend the super flower PSU? is it that good?
vtecXx
Yup..will do that and saw mentions of efficiency. Anymore recommendations I shld look at bros?
cKm
I'm using the same CPU as you and it still works fine. With a 1K budget I'd suggest the following:
1. Add more ram
2. Replace GFX card
3. Overclock + Change CPU Cooler.
vtecXx
1. Add more ram
2. Replace GFX card
Ok I already intending to do 1-2. Noob qn next, change cpu cooler means changing the fans? Will it be tedious??
liewhl
your rig is still ok. just change your ram to 8 gb and upgrade your gpu to 280x or better.
psu still can keep unless you adding a lot of thing
then the rest of your money spend on other thing like lazer mouse, mech keyboard or monitor
if still have $ left, buy canned compress air or invest in a electrical blower to clean up your cpu/case fan and your other interior part.
you can also keep your casing and just change the case fan. if you want a new case get a corsair 540 air.
vtecXx
Ok..I think I will change my fans. My casing still pretty durable less the rust n dirt from the past.
Gpu 280x now is the bare minimal? How does the gtx rake up against it
