Need Help with 3.5K part list
ninjassword
Hello! This is my first time buying a custom PC.
This list is slightly over budget, what do you guys think of this build and what do you suggest i save on?
Thanks!
Since I cant post links to PC part picker, heres the parts:
CPU
Intel - Core i7-8700K 3.7GHz 6-Core Processor
CPU Cooler
Corsair - H100i v2 70.7 CFM Liquid CPU Cooler
Motherboard
MSI - Z370 GAMING PLUS ATX LGA1151 Motherboard
Memory
Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory
Storage
Samsung - 960 EVO 250GB M.2-2280 Solid State Drive
Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive
Video Card
MSI - GeForce GTX 1080 Ti 11GB GAMING X Video Card
Case
Cooler Master - N300 ATX Mid Tower Case
Power Supply
SeaSonic - PRIME Gold 750W 80+ Gold Certified Fully-Modular ATX Power Supply
Koenig168
I haven't totalled up the cost of your parts but off-hand, with a 3.5K budget, you should be able to do much better.
Parmesean
May I ask what the main use of the system will be? If you are gaming, an i5 would be a much better choice, and it also shaves off money from your budget, to put towards something else.
If you have the money to spend on an i7, then go for it, just that it's a little overkill for gaming.
kracie17
what would be the purpose of the system? the money could be put to good use for eg. getting a good monitor.
ninjassword
Yeah it's for gaming, however I do programming too. What do you suggest Then?
kracie17
Gaming mainly, I do programming too. I put aside 400 for a 144 hertz monitor
okay. but do you require i7 for gaming? unless you intend to programming and game at the same time which i think i5 would be sufficient or that is of course you do not mind spending that amount unnecessarily.. we trying to be more practical.
Can you give me the list of par5s? Thanks
according to Koenig168, he was referring to your specs provided but have yet to sum up the total value.
ninjassword
Oh i see, its about 3,520.40 if i used google to covert the money. ( since i using UK pc part picke)
