Need help with asrock mobo
freezeblade
so today i bought an asrockz97 killer board with a 4790k and i installed it all however i run into two problems. one is that i cant seem to get any sound from my mobo rear audio jacks and i cant figure out why. secondly i have a archer t4u usb wifi adaptor in my build and i thought that it would be a good adaptor but it seems like soomething is wrong since im getting really crap speeds on it. im confused, i installed the drivers already but it is still really bad help pls
Ark Law
Plug into green hole. Personally, I only trust Intel wifi stuff to be reliable. You can bet on Asus but there are considerable number of lemon sets out there
raysusan
i juz had my upgrade like you too..but i choose msi ..did u install the driver already?
freezeblade
thanks man. the green hole worked. now to figure out if my wifi is working properlyu
freezeblade
so audio is done but my wifi problem is still here
installed my adaptor drivers as well as my mobo driver and utilities. not sure what is wrong but wifi is still cchoppy
freezeblade
really would like a bit of help. steam downloads at decent speeds but my browsers have really bad download speeds
Maeda_Toshiie
With regards to WiFi adapters, the best is to get one that has a cable that allows you to place the antenna such that it is not hidden. Brand does not matter as much.
Ark Law
Which is why I said personally. Because my friend ran into 2 consecutive lemon Asus sets having recommended him the highly-acclaimed PCE-AC68. Good design but rubbish QC can be affected by choice of brand as well. But you put it well regardless.
