Need help with budget gaming build.
freezeblade
Already have case, gpu, os, ram. Need the rest of the parts. Budget about 900?need monitor as well as an ssd. Preferably 2tb hard drive. Need to be able to play dota 2 and Max out Saints row 4. And handle far cry 3 on high
royfrosty
Whether the game can handle high details or not is depending on your GPU.
MSI B85 G43 Gaming + i5-4460 ~ $383
Crucial mx100 256gb ~ $155
WD Purple AV 2tb ~ $124
Supeflower HX500 500w 80+ Gold Semi Modular PSU ~ $88
LG DVD Drive ~ $21
Total ~ $771. Buy at tradepac. DIY
royfrosty
Gtx760 still can play mid high settings for the games you mentioned. But if you crank up AA then might have an issue.
