OneAngryDog
- Apr 29, 2015
Hello and Good day,
First time on the forums, I hope someone can help. I'm getting a new CPU and I am clueless with all the advancements. I'll like a "DIY" version that the shop can assemble instead of a branded or package version.
I'll be using the new CPU with my Samsung LCD 42 inch wide screen monitor which I believe can go up to 1920 x 1080 max resolution. (it's presently max at 1360 x 768)
I'll be running SketchUp (CAD software), Photoshop and similar, Windows Movie Maker, other from that I'll be doing heavy internet surfing and streaming movies.
I read that I'll instead of a 2D, I'll need a 3D Graphics card and lots of RAM to run the CAD software. Oh ya, I don't do any gaming.
Do I need to buy Windows 7 software separate or do they offer it together?
Do I really need an anti virus software?
My budget is $1000. Please recommend the components types, prices and a good shop I can buy from.
Minimum Requirements:
Motherboard?
Intel 4 Gen, 3.60 GHz processor.
1.0TB HD.
8 GB Ram.
3D class graphics card with 2 GB of memory. Driver that supports OpenGL version 2.0.
64-bit versions of Windows.
DVD Writer.
Sound system ? (something basic)
Casing ? (Since I work at home and my PC is on for may hours do I need any particular Fans or Power Supply? )
Thanks in advance!
Motherboard?
1.0TB HD.
8 GB Ram.
DVD Writer.
Thanks in advance!
