Need Help With Building A Desktop
pleopleo
Hello all,
I have not custom build a desktop before. I am looking to build a custom gaming pc with a budget of S$1,000.00 to play Dota 2, Diablo 3 and Killing Floor smoothly at max setting. Is it possible? Any advice please. Thanks in advance!
Jian19
Keyboard / Mouse
$1k
i5-4460 + Asrock h81m hds ~ $337
G.skill 8gb ddr3 ~ $87
Wd blue 1tb ~ $75
Powercolor 270 ~ $229
Fsp hexa 550w ~ $68
Samsung oem drive ~ $24
Coolermaster n200 ~ $55
Win8 64 oem ~ $135
$1010 buy and assemble @ pctheme ask for discount.
pleopleo
Keyboard / Mouse
$1k
Wd blue 1tb ~ $75
Fsp hexa 550w ~ $68
Deepcool smarter ~ $49
Win8 64 oem ~ $135
$1004 buy and assemble @ pctheme ask for discount.
May I know how is the cooling system for this desktop? I had very bad heat issue with my current cpu.
Thanks for the configuratiin too. Any other possible configuration?
zenniz
By the way, Deepcool smarter doesn't come with intake and exhaust fan. You need to buy them separately. Intel's stock cooler is adequate.
R9 270 is more than enough for Dota 2 and killing floor. You can even play battlefield 4 at high setting with it.
pleopleo
is there any case that comes with intakr and exhaust fans then? How much is an intel stock cooler?
trento
the gpu is not very hot under load so stock cooling with single intake exhaust will do
zenniz
The fan will always keep the GPU's temp below (room temperature +50 degree Celsius) regardless of how long you play.
pleopleo
If my budget is 1.5k, what should I get then?
In addition, what are the differences between amd gpu and nividia gpu then?
Jian19
Amd gpu is better price / performance
Nidvia gpu is better @ efficiency and temp
$1.5k
i5-4460 + Msi h97m g43 ~ $418
Crucial bx100 256gb ssd ~ $158
Wd blue 1tb ~ $75
Msi gtx960 armor oc ~ $339
Superflower leadex 550w ~ $129
Fractal design arc midi r2 ~ $139
Win8 64 oem ~ $135
$1504 buy and assemble @ pctheme ask for discount.
trento
some games are optimised for nvidia. so u may lose some performance.
pleopleo
$1.5k
Wd blue 1tb ~ $75
Win8 64 oem ~ $135
Is it possible to get msi gtx 970 gaming 4gb for this configuration for budget of 1.5k and then remove ssd? Windows 7 or 8 better?
