Need help with building a gaming rig!
pshcyo
hi guys,
i'm looking to build a gaming new rig, low midrange, and i need advice on the parts and prices
My requirements are;
-For the GPU i need something that can play a game that has the graphics standard of assasin's creed 4 at high (hopefully max) settings (r9 280x?)
-Mobo that supports usb 3.0
-1tb hdd (ssd will be bought separately from amazon)
- i5 processor (any real benefit of buying 4xxx over 3xxx CPU?)
-budget of about 1.2k
any recommendations??
also, are there any other parts that can be bought from amazon which have significant discounts over sls?
Jian19
280x not low mid range Liao..
Stat ur budget better for us to recommend
pshcyo
haha ok mid range (w/o low)
edited to include budget.
are there gpus which are cheaper but can meet the requirement ahh?
Jian19
Need monitor ? OS ?
1.2k
i5-4570 + Msi b85m g43 ~ $347
Crucial 8gb ddr3 ~ $90
Wd blue 1tb ~ $74
Powercolor 280x ~ $425
Seasonic s12g 550w ~ $99
CM n200 ~ $60
Win7 64 oem ~ $115
$1210 buy and DIY @ tradepac ask for discount.
Can consider gtx760 which should be able to play the game quite smoothly on high settings.
pshcyo
Need monitor ? OS ?
1.2k
Wd blue 1tb ~ $74
CM n200 ~ $60
Win7 64 oem ~ $115
nope no need both reusing.
i heard 280x gives better performance than 760ti...?
Rashkae
Look at the buyer's guide sticky, there's a build for every budget. :p
Jian19
There is no gtx760 ti yet..
Yes 280x = gtx770 performance
Gtx760 is a mid range card price around $320-$350
Jian19
Since no need OS can invest on better psu and case
Seasonic g550 ~ $108
Fractal design arc mini r2 ~ $120
Ssd actually can buy locally if u thinking of bang for bucks
Crucial m500 240gb ssd ~ $189 (amazon $160 need to wait and if rma need to send back)
pshcyo
sorry noob qn, but what are the purposes for better psu and case? i only know better case looks nicer...
Jian19
G550 is semi modular power supply which will gives u better cable management and cleaner build
Better case for better dust prove, air flow, cable management etc
It's up to u really, if u wan to save $ then the first recommendation is perfectly fine
CM n200 is a good entry level case as well
pshcyo
alright thanks a lot for the advice, and the rig recommendation!
pshcyo
Need monitor ? OS ?
1.2k
Wd blue 1tb ~ $74
CM n200 ~ $60
Win7 64 oem ~ $115
hi, if i were to get a 760 instead, which model of 760 should i get? and 660ti vs 760 which has a better bang for buck?
MoneyFace =p
hi guys,
CPU+MB: Intel Core i5-4440 + ASRock B85M Pro4 @ $328
Cheaper, yet with Intel Gigabit LAN.
RAM: Crucial DDR3-1600 CL11 4GB X2 @ $94
GPU: Zotac GTX 760 2GB AMP! Edition @ $348 (mynextcom)
SSD: Crucial M500 240GB @ $175 (t258jgn)
For just $15 more, no waiting time, no troublesome overseas RMA/
HDD: Western Digital Blue 1TB @ $72
ODD: Samsung 24X CD/DVD Writer [OEM] @ $21
PSU: Seasonic S12G 550W [80 Plus Gold] @ $99
CASE: Antec X1-T [Window] @ $75
Total: $1212
Buy others from Tradepac, #05-18.
killerslayer92
I recommend msi gtx 760 twin frozr
2gb or 4gb, u decide. :)
760 2gb. 4gb is for 4k and the 760 wont run 4k smoothly so juz get 2gb
juz get a zotac or palit... they cost less. i rmbring getting for my friend a zotac 2gb "high end ver" with twin fan for less than $350 frm tp.
MoneyFace =p
And Zotac comes with 2+3 years warranty.
