Need help with building a HTPC.
MajinBuui
Need recommedations building up a HTPC to connect to tv.
Budget $350
My usage: surf net, youtube, watch PPS, watch videos, download torrents, play videos from external hd and internal hd.
What I already have: 4GB RAM, ASUS GEFORCE GT 610, windows 7 OS
What else do I need?
MB - ???
Casing - ???
CPU - ???
HD - 1TB
Any other stuff - ???
Remote control - ???
I would like to just buy all the parts from same store and ask the shop staff at simlim square to build it.
Thanks!
royfrosty
Asrock b75m dgs + intel Celeron G1610 ~ $119
Seagate 2tb ~ $113
HEC true power 300W ~ $35
Sharkoon MS140 ~ $52
Samsung ODD ~ $21 (optional)
Total $340 Buy at tradepac. DIY.
Assembly $10. Unless you know how to bargain for free.
t258jgn
Jonsbo S1 Micro-ATX HTPC Case + Jonsbo HTPC IR Remote Controller & Receiver
jb-htpc-remote-04.jpg~original
Ian
Asrock b75m dgs + intel Pentium G1610 ~ $119
Seagate 2tb ~ $113
Intel Pentium G1610 got GPU Integrated?
Yo2020
Thx for the input but the sharkoon ms140 casing seems big..
Can any1 recommend full set from PC themes?
Price Lists - HardwareZone.com.sg
must be able to fit in my exsiting GEFORCE GT 610 thanks yet small casing!
I think i wan from there.
if u need to use graphic card, one of the smallest cases is in-win bm series such as bm639.
but actually gt610 is a very entry card, it is not much faster (if faster) than ivy bridge-class celeron or pentium. if u want something sure faster than gt610, top up abt $110 n go for the new haswell-class pentium. eg. pentium g3320 + asus h87i itx. see tradepac's pricelist. by using only igpu, u will hv option to choose a much smaller case like antec isk110. :D
