Need help with building new desktop~~
huimeng
I have always been using laptop and decided to build a desktop at SLS for gaming and watching shows.
I have no experience with desktop and have a lot of questions which I hope you all can help me.. /:
My budget is around 1.3k to 1.5k including Dell S2340L 23inch ElPS Panel.
Games that I will be playing are : Dota2, Street Fighter 4 on the PC, maybe upcoming games that can be purchased on Steam.
My questions are, i5 or i7? I seen most reccomendations points to i5-4xxx.
Does having a SSD really gives you a total different experience with desktops?
power color 270 or Palit GTX 760?
I have a modem in my living room and has always been using wireless on my laptop in my room. The desktop have to be in my room. How do I work around this problem? I read thru forums and they talked about wireless adapter. Or is there anything that can act as a router for me to connect to the wireless?
Ark Law
Yes. You can go kill yourself if you choose not to use SSD today.
GTX760.
FlyingNuggets
I suggest i5-4690 its just nice for gaming and its a quad core processor so its more than enough for gaming and normal usage!
GTX 760
royfrosty
1.5k everything in
MSI B85M G43 + i5-4460 ~ $355
Crucial 8gb 1600mhz Value Ram ~ $95
WD Blue 1tb ~ $67
Crucial MX100 256gb ~ $161
Palit GTX760 2gb Jetstream OC ~ $346
Superflower HX500 500w 80+ Gold Semi Modular PSU ~ $88
Sharkoon BD28 ~ $72
Samsung DVD Drive ~ $21
Windows 7 Home Premium 64bit OEM ~ $110
Dell S2340L 23inch eIPS Panel ~ $219
Total ~ $1534. Buy at tradepac. DIY
huimeng
1.5k everything in
WD Blue 1tb ~ $67
Sharkoon BD28 ~ $72
thanks royfrosty for the reccomendation. (Y)
regarding the wireless issue, does using the wireless adaptor gives the same effectiveness as a laptop connecting to wireless?
Ark Law
Afaik, an Intel one would provide you with the same effectiveness. YMMV with typical TP-Link, DLink and Asus wireless adapters in terms of performance and reliability. With Intel stuff, it normally "just works" :o
Amazon.com: Intel Dual Band Wireless-AC 7260 plus Bluetooth Adapter (7260HMWDTX1): Computers & Accessories (Cybermind sells this kit for SGD99 iirc)
huimeng
Had this built set up at tradepac. Thanks roy for the recommendation :D
2 issues im having at home right now.
Bought Asus PCE-N15. Wireless speed is great but is having frequent packet losses. Disconnecting every 15sec for 1-3sec.
The WD Blue 1TB wasnt detected in my computer. I only have the SSD in my drive.
Godeau
Can't help you much with the wireless adaptor, maybe you can disable any power saving options. Or you're just too far away/too many walls from your access point.
For your 1TB hdd, it is not formatted yet, so you will have to format it to be usable.
Assuming that your bios has the drive detected(should be called WD10EZEX or something..)
Right click on 'My Computer'
Click on 'Manage' to go into computer management
Below, click on 'Disk Management'
Once there, all your drives will be displayed, find the one with 900gb+- or so storage space and format it. It'll take a while so I recommend you just afk :)
Ark Law
That's why I recommended you the Intel one. Non-Intel stuff reliability are typically never really a known quantity
Godeau
Out of curiosity, I googled for a review on the Asus pce-n15..
Likes
Low Game latency
Clean User Interface
Software Access Point
Easy setup with Linux
Dislikes
Performance quickly drops off with distance
Performance-wise, this is an average card. The only issue was that the peak bandwidth dropped off pretty quickly once moved away from the router. At a distance of 5ft, the PCE-N15 pulled 76Mbps and had a really solid lead over the DW1501 with only 42.5 mbps. Moving out to only 25ft, the PCE-N15 dropped 29Mbps to 47Mbps and the DW1501 only lost about 1 Mbps. A lead of only 5Mbps on such a short distance of 25ft is kind of disconcerting. The speeds were still well within the 802.11n range, but it's not my first choice as a gamer if I had to use wireless. As long as you don't need to do anything extreme, it will happily serve up YouTube, Netflix and high-def movies over your home network.
25ft = 7.68metres
Sauce.
royfrosty
There you go.
royfrosty
Got to check your distance. Most probably your 2.4ghz signal cant reach your place.
huimeng
Thanks for the reply. Under Disk management, the hdd is unallocated. It has the options initialize disk and then convert to Dynamic/GPT disk.
What do i do with it?
EDIT: Google-ed for the answer. Option > New simple volume.
Thanks
