Need help with current budget ideal rig.
  • Have you been Scammed?
Slaughterman666
Hello, does anyone know any other online shops that sells reasonable prices for PC parts in general.
Or if they have other PC retails shops apart from SLS itself? I'm currently still new to general PC building despite having replaced my older one with newer parts.
I've seen through many but am wondering if there's any more
1. Newegg
2. Amazon
3. Shopee
4. Lazada
5. Qoo10 (most expensive)
6. Carousell (Scammers?)
I'm trying to build a pc from scratch starting with the mobo + cpu before I can fan out to other parts.
So far my budget is under $800 as I have an RX570 powercolor GPU for now.
Current budget rig list
Mobo : ASRock B450M PRO4 R2.0.
CPU : Ryzen 5 3600 processor or 2600 as I'm looking for 6 cores and 12 threads for my work and leisure gaming time.
CPU cooler: (anything cooler master cuz I like the brand <$80)
GPU: (Re-using my RX570 powercolor 4gb)
Memory storage: (Corsair, Adata or Crucial at the moment - 512gb < $100 - 120)
RAMs: (Thinking of Crucial, Crosair or Adata if possible)
SSD: (Samsung, Toshiba or any affordable types)
Case : (More onto air flow than liquid)
Fans : (Good ones with quality RPMs and build)
Sorry I can't think of much until now. Prices in SLS seemed reasonable but I noticed only Bizgram and Dynacore were trustworthy as compared to BestPrice and the new one called CityZone. My old PC rig is unable to keep up to the newer ones so I have no choice but to start a new rig as I5-I7 7th generation CPUs are extremely expensive.
NightRaven49
there is also taobao if u are literate in chinese. if u are willing to give up local warranty, generally cpu and mobo bundles there are extremely attractive, for eg u can get the msi b450m mortar (imo the best matx b450 board) with the 3600 for just $300 with free shipping.
see above. otherwise sticking with sls is a safe choice too.
can consider the hyper 212. cheap (should be under $50?) and reliable.
these parts better to go amazon.
can consider arctic p12. almost as good as the top of the line noctua nf-a12x25 in terms of noise, but at a fraction of the price. can find for about $10-$15 per fan.
Slaughterman666
Thank you. Just another question.
Do I need to find compatible RAMs with the Ryzen 5 3600 processor? I noticed on some other videos that they had some RAMs being not compatible with it due to the speed rate itself
