Need help with faulty SD cards
Little_Demon
Hi, I have 2 SD card that cant be format. I had goggled and tried many ways like downloading a software to format and using command prompt to change the wite protection but still cant format.
Is there any shop that can help me with this issue? I dont mind paying a small fee to resolve the problem. Please recommend. Thanks.
Little_Demon
Not lock. That is the first thing I checked.
I also tried is a solution in youtude that uses tape to cover the small slot at the other side of the lock to enable formatting. But mine still cant format.
Alphas
It is gone, cannot be recovered, ie the nand are died.
Louisloo
If you cannot format and there is no data inside that is important, it is better to buy a new one. Why you want to risk it storing data inside.
