Need help with first gaming rig
Yi_xian
Hi,
This is my first time making a gaming rig, my budget is around 1.3 for the CPU itself and maybe $200 for a monitor?
This is some of what I have chose from my research at tomhardware guide.
please help me out ! Thanks!
I also need a CD drive and wireless internet is used at home
Monitor : DELL E2416H 24 ($198 at lazada)
Case:Cooler Master MasterBox 5 (like that it's transparent)
CPU: Intel Core i5-6500
Graphics: Asus Gtx 1060 6gb
Motherboard : Gigabyte GA-H170-D3HP
Ram: any 8Gb Ram(future upgrade to 2 8gb?)
SSD: Samsung 850 EVO - 500GB (overkill?)
HDD: WD 1TB
PSU: Corsair RM550x
Will all this work? I'm really sorry if it's a mess. Really noob here...
intrance
All good...
Have you calculate total price of your choosen parts?
Looking at it.. im sure it will be more than $1300.. and yet not include wifi adapter, cd drive and OS..
will you consider other configuration than above?
Yi_xian
I dont really know where I can get the price.. n
Yup! What do you recommend?
intrance
MSI B150M BAZOOKA PLUS + i5 6500 @410 (PCT)
KINGSTON 2133MHZ @52 (PCT)
ZOTAC GeForceĀ® GTX 1060 3GB*@299 (LAZADA)
SanDisk SSD Plus 240GB @93 (LAZADA)
WD 1 TB BLUE HDD @74 (PCT)
Superflower Leadex Silver 90+ Full Modular 550W @119 (LAZADA)
Asus PCE-AC56 Dual-band Wireless-AC1300 PCI-E @99 (LAZADA)
WINDOWS OS @30 (REDDIT)
TOTAL @ 1176 (not include Lazada discount)
Casing: Get whatever you fancy.
If you like a red/black theme.. can look at MSI B150 GAMING PRO
Im sure other bros here will share their suggestion and recommendation to your inquiry..
Yi_xian
Thanks a lot to both of you! I will take note! Seems like I can save a lot more with similar specs items.. šŸ˜…
Yi_xian
Intrance, how about zotac gtx 1060 6gb amp edition? For $100 more is it worth?
wwenze
Note that price quoted by forummers is usually the best price they can find. So they can find 6GB that is cheaper than $399 also. Just ask them.
IMO, the extra 10% processing hardware of the 6GB variant is worth something, but more importantly it can run Mirror's Edge at full settings without running into ram limit.
foo9883
Yeah ample vram more impt than the 10% more processing power when jumping from 3gb to 6gb for 1060.
The moment ure vram run out and have to swap textures and stuffs into system ram fps will drop dramatically.
The mirror's edge 970 4gb vs 390 8gb video below.
https://www.youtube.com/watch?v=Bm5ZCJah-FY
Yi_xian
Ok, so i should try and find a 6gb card if I can right? Anyone have any lobang for the more worth 6gb card?
MianBaoFren
