Need help with gaming rig
Midnight Saga
Hello, I am planning to assemble a gaming rig in 2 weeks time and I need some help.
My budget for this will be 1.5k - 1.6k and around $250 for a 23" monitor.
I would like to include the following:
1. 128gb ssd
2. 2x 1TB hdd
3. 8gb ram
4. wifi card
5. speakers
6. extra fans, or a cooler cause its going to be placed in a corner and I plan on leaving it on for long periods of time.
Things to leave out: OS, keyboard + mouse
All suggestions are welcome :)
Thanks in advance :)
royfrosty
My budget for this will be 1.5k and around $250 for a 23" monitor.
1. 128gb ssd
2. 2x 1TB hdd
3. 8gb ram
4. wifi card
5. speakers
MSI B85m G43 + i5-4570 ~ $356
ADATA 1600mhz 8gb ram ~ $85
WD Green 2tb ~ $110
Corsair Force LS 120gb ~ $141
MSI r9 280x 3gb twin Frozr + Superflower HX600 600w 80+ Gold Efficiency PSU ~ $529 (mynextcom Deepavali promo, GET IT NOW before its too late)
Fractal design Arc Midi ~ $129
TPLink N150 USB wireless Adapter ~ $20
Dell U2312HM 23inch IPS Panel ~ $248
Samsung ODD ~ $21
Creative SBS A220 2.1 speakers ~ $35
Gentle Typhoon AP15 fan 3x$25 ~ $75 (PCthemes, cybermind, best price)
Total $1749 just nice including monitor. Buy from tradepac. DIY.
Please get the GPU and PSU combo asap, once it is gone $60 saving is gone for good.
shadow84
get from #02-01.... They are selling at $20/piece... tradepac do sell as well....
Midnight Saga
Samsung ODD ~ $21
I actually have a Samsung Super Writemaster. Is that okay?
Could you also explain a little bit about the differences between a wifi card and a wireless adapter please?
royfrosty
ODD is more of an optional thing. I barely use it lol. Like once in a year thing. You can continue to use your ODD.
A wifi capable desktop has 2 options: 1 is via a USB thumbdrive look a like.
The other is a PCIE internal type. Internal is slightly more expensive. But to me i personally felt that PCIE internal type signal is stronger as it comes with Antenna.
USB type comes in 2 types. One is thumbdrive and the other is a USB wired power type.
USB wired type usually do comes with antenna. Usually strong signal also.
But if your router is near your desktop, just get the USB thumbdrive type.
Midnight Saga
I see, thank you for your help. I think its basically settled. I will get the setup you suggested. Thanks alot! :)
