Need help with Micro in excel
curo
Hi, I'm trying to create a cell that will display the last saved date of the worksheet automatically.
I did a google search and found this code:
Function LastSaved() As Date
Application.Volatile
LastSaved = ThisWorkbook.BuiltinDocumentProperties("Last Save Time")
End Function
But the problem now is when I formatted the cell to display date, the date is incorrect. It show year 2017 and date is next day. So its like showing the future. Anyone know how can I correct this problem so show tat it is today date?
Thanks
ctingyee
Can you check your computer's time (just mouse over the clock)? Maybe it is showing the date you saw or you forgot to change the time back while using function.
I used the function in module shows date is okay.
curo
I checked. My computer time and year is correct. Time also correct. That is why I am stuck..
ctingyee
Okay... How about that excel file. Can you check it at explorer? If the file last saved on 'future' date, I think is correct.
Haven't you edited the file, saved it, closed and reopen the file to check the result?
curo
i even tried the formula =date(). It show the correct date and year. I redo the micro but same problem. (edited, save, close and reopen)
ctingyee
Interesting. I used Excel 2010, new macro-enable excel file. Looks fine to me.
If I saved today, I get the value 41508.49111 in number. Before you set to date format, what's the value?
curo
I got 41508.47159.
So different from yours
ctingyee
That value is correct, 41508 means today date (2013/08/22) and the floating value is the time.
If you format date on cell that value 1.99999 should be 1900/01/01 23:59:59
I don't know why your 41508 refers to year 2017.
You use office mac version?
