Need help with motherboard.
hengheng220
If looking for durability, all of them are the same is just a matter of luck whether it's gonna spoil or not. If you really worried I would advise going for Asus for the 5 years warranty. But on a side note are you overclocking or using sli or crossfire? If not b85 vanguard Asus should be ok le
The_King
no. not planning to overclock or sli
just need a motherboard for durability/longevity. and needed mobo to have optical out for my Av receiver.
my current mobo is a intel DG33FB. i think over 8 year old. and it time for this board to retired. if only intel sell board
The_King
i thought of that, but don't have optical out.
The_King
since i dont have own a avr before, i think it better to play safe and get a board with optical out, while the gpu HDIM can send the HD audio to the receiver
my idea was to buy a $400 plus gpu but in the end i decided to get a gpu of less then $180
use the extra money and the money for the blue ray and get a PS4.
hengheng220
actually imo most of the quality of the sound are almost the same unless you are super sharp and using high end speakers or headphone then can hear out.
The_King
thanks guys, i know what to choose already. cheapest board with those so call better parts
