Need help with my first PC rig
xMorphine
Alright thanks a lot guys!
Right now these are the changes I've made to the list thanks to all of you :
CPU : i5-6500 3.2GHz
Mobo : Gigabyte GA-B150-D3H
GPU : Zotac GeForce GTX 1060 6GB AMP!
RAM : G.Skill 2133MHz CLI5 (2 x 8GB)
SSD : OCZ 240GB SATA III Trion SSD
HDD : Western Digital Blue 1TB 7200rpm
Power Supply : Leadex 550W Silver Power Supply
OS : Windows 10
Optical Drive : Whichever one that costs like $20
Casing : Corsair Spec 01 RED
Based on PC Themes list (+ Windows 10 from reddit) it should total around to $1404 so I'm very satisfied with that. Hopefully I can get a discount for building it with them :D
ZrE0_Cha0s
OS : Windows 10
pay in cash might get discount.;)
shadow84
Does this work for irregular customer or first time buyer?
They prefer cash so as to skip those extra charges and time required to go get the cash out. Then again, it depends on how u use your mouth as well.
undead102
Think your specs looks good. Think you can just get 1 x 8gb RAM instead 16 gb is overkill. Channel the extra money into a better GPU.
xMorphine
Sorry, one last question. Is it common practice for shops to accept payment in installments or is that only for their own offered PC builds?
Allanlee82
mostly shops dont offer installment, if you want installment plans, you might have to check with your own bank.
other than cash, they will most likely charge you an extra 3% so the best is pay by cash
xMorphine
Alright cool, thanks for the info!
paul02
Yup I've been using the same 1080p monitor for console gaming and it still works fine so I think I'll go for the 1060. However if I decide to upgrade to 1440p (don't think I'll go for 4k), the 1060 should still be able to handle it?
It should be able to and you can get feedback from other members here.
Paying in cash allows you to get a cheaper price. Do it.
