Need help with my graphics
Zenzevil
I just bought a custom build rig and I have a GTX 1070 as shown below.
But my PC is only recognizing the integrated graphics. How do I solve this?
And also, I tried opening NVIDIA control panel and this shows up.
[/IMG]
tigerwoods
disable the integrated graphics in bios and windows device manager
Thank me later
LiquidMan
Actually I think it's connected to the mobo. Anyway when I reboot and went into BIOS again to check, the integrated graphics had reset itself.
I think you may want to connect your display (via HDMI/DVI ) to your graphics card instead of mobo.
The graphics card connector should be lower on behind your CPU not near the USB ports.
Zenzevil
Okay so I connect my DVI cable to my GPU instead of my mobo. But it's even worst, got to loading screen and then black screen, no start up.
MrMundy
Uninstall the Nvidia software and driver first then
Reseat ur GPU(take out and plug back)
Reset bios
Connect monitor to GPU
Boot up
Install Nvidia software and drivers
Zenzevil
It's working fine now, it's my monitor problem. I have to adjust its settings. Thanks guys.
