Need help with my iMac
ahsiao80
Hello peeps!
Need help with my iMac, ever since i bought this iMac, i encounter the errors shown in the pictures below frequently. i'm pretty sure the website was working fine,tried updating my Mac but it does not help at all :s22:
My previous Macbook Pro does not seems to have this problem and it was serving me for a good 3 years. Could i have missed out any software which should be downloaded or should i sent my iMac for repair :eek:
havetobuy
why dont u try with Chrome..if still sama sama..than liked some1 says DNS problemo
B772ER
most likely DNS issue. try power cycling your devices and also forcing google public DNS servers in sys prefs > network > wifi > advanced > DNS
ahsiao80
Thanks for the help guys! What setting should my DNS be? i'm on starhub cable still leh :/
ahsiao80
PetPet
Moderator
Moderator
Thanks for help! i was on auto DNS configuration but i just flush my cache again :/
hmmm what does this do? cause i was reading with the above link, DNS panel should be cleared :s11:
8.8.8.8 and 8.8.4.4 is Google's Public DNS.
By using them, you'll be using Google's Public DNS to resolve your domains instead of your ISP's.
