Need help with my rig
origamii
can check with anyone whether the below build can be adjusted to reduce cost.
Intel i5-4570 Desktop Processor
asrock b85m pro4 motherboard
Gigabyte R9 280x
Samsung DVD Writer Super WriteMaster 24X SATA (SH-224)
WD Caviar Blue 1TB SATA / 64MB Cache (WD10EZEX)
G.Skill RipJaws X 8GB (2X4GB) DDR3-1866 CL9(Red)
NZXT Phantom 410
Corsair Force (LS) 2.5" SSD 120GB SATA3
Corsair TX650W psu
Monitor i maybe will get Dell 23 inch monitor.
royfrosty
Drop the idea of phantom 410. Won't have any wire management.
With that price get the fractal design r4 or arc midi. Or if you up for it get the corsair carbide air 540.
Ram just get the 1600mhz. You won't find a performanc difference..
Drop the corsair ssd. Get the plextor m5p cheaper.
Try the superflower hx600 600w 80+ gold rated PSU. Should b slightly cheaper.
Jian19
i5-4570 + Msi b85m g43 ~ $356
Kingston 8gb value ram ~ $93
Plextor m5p 128gb ~ $160
Wd blue 1tb ~ $80
Gigabyte 280x ~ $445
Superflower hx600 ~ $110 (mynextcom can ask tradepac match price)
Corsair 350d ~ $140
Samsung oem drive ~ $21
Total $1405 buy and DIY @ tradepac ~ ask for discount
Casing up to which one u preferred..
royfrosty
y cannot phantom 410? or is corsair 350d better?
The wire management area is terrible. I see now if SLS got demo can take a pic of it show you the management area. Corsair 350D is a much better chassis. But take note it is a matx chassis.
origamii
Wd blue 1tb ~ $80
Corsair 350d ~ $140
mobo how come take msi instead of asrock?
asrock have fast boot rite?
ssd can use a brand Adata?
powercolour 280x now cheaper than gigabyte? i saw the price at bizgram at 426
powersupply wise i think choosing corsair or should i take GS instead of TX
this build able to play BF4 at which setting?
royfrosty
GS is not even a modular PSU.
Get the giayte variant. Slightly better cooler.
Adata get the plextor one with synchronous.
Jian19
Bf 4 very demanding ~ consider quite good le, u can turn down a few details to improve ur frame rate
IMO first person shooting game fps around 50-70 consider good and smooth
Above 70 is butter smooth :o
shadow84
hijack abit, fractal design r4 also matx right? it look small
ATX case.. can support ATX, mATX, ITX boards... Look small to you, meaning you physically seen it or based on reviews?
pcie n pci wats the diff?
PCI is old gen, nowadays we are using PCI-e, which is very small. Only gpu uses the longer PCI-e for more bandwidth.
voiceoflove
ya seen it physically side by side vs 750d
