Need help with parts recommendation
lucaslyh
Hello guys, first time posting in this section.
Im intending to get a setup with i5-4690k, gtx 970 and 8gb ram. Im not too sure about mobo and the likes. My qn is will a rig like that be able to fit into my 1.6k budget. If not, what can be substituted with similar capacity.
lucaslyh
my friend told me i can use a ;) version of it. but an official one would be nice if can fit in budget
pineapplepeng
Have you bought any components?
If you want cheaper option the MSI Z97 PC Mate is pretty good and cheap.
For example,
CPU+Mobo: MSI Z97 PC Mate + i5-4690k @ $430~
RAM: Corsair/Kingston 1600MHz (4GBX2) @ $105~
GPU: GTX 970 depends on your preference, you may want to get from Lazada during offer on 7-9 April
PSU: Corsair CX 600W Semi Modular 80+ Bronze @ $110~ ,may want to wait for Lazada sale as well.
HDD: 1TB WD Black @ $100~
SSD: Samsung 120GB 840 Evo @ $110~, may want to wait for Lazada sale.
Case: Up to you but would be below $200 probably
OS: Windows 7 Home Premium/Windows 8 Home Premium @ $130~
Total @ $985~ without GPU and Case
So you would have $615~ budget for both GPU and Casing
However if you decide to wait for sales and discounts from Lazada or other places, you may have more money for your GPU/Case
Do note my pricing may not be the most accurate and only serves as a general guide.
lucaslyh
For example,
Thanks for the recommendations, i dont really have a rough idea on how the other parts would fit together so i havent bought any yet. If possible are u able to recommend other part variation with similar specs? I play guild wars 2 quite enthusiastically nowadays. It seems the gtx970 and i5-4690k combo quite tight for my budget
mib500
if you OC then you no need to buy K version and Z mobo... just buy i5 4690 non k and H mobo....
lucaslyh
lol i don't think he cares. but i'm curious, after spending hundreds of $$, why would you let a pirated OS run your system?
if im able to get better specs then i dont mind la, but if possible i also want the genuine version=:p
pineapplepeng
Well actually if you don't mind you should get some parts 2nd hand to decrease your spending, but its personal preference. For example RAM if you get 2nd hand there is no difference since most RAMs are covered by lifetime warranty
MoneyFace =p
It's possible. :)
With some cash to spare. And a nice red and black theme. :evil:
CPU+MB: Intel Core i5-4690K + ASRock Fatal1ty B85 Killer @ $417
HSF: Xigmatek Dark Knight SD1283 [Night Hawk] @ $59
RAM: G.Skill RipJaws-X DDR3-1600 CL9 8GB Dual Channel Kit [Red] @ $114
GPU: MSI GTX 970 4GB GAMING OC @ $489* (Lazada Singapore)
SSD: Lite-On S900 256GB @ $138
HDD: Western Digital Blue 1TB @ $70
ODD: Samsung 24X CD/DVD Writer [OEM] @ $21
PSU: FSP Aurum S 500W [80 Plus Gold] @ $89
CASE: Corsair Carbide SPEC-02 @ $84
OS: Microsoft Windows 7 Home Premium 64-bit [OEM] @ $110
Total: $1591
Buy and Build at Tradepac, #05-18.
*Price after $100 Lazada coupon discount (TBA later)
lucaslyh
It's possible. :)
Total: $1591
If i were to OC the cpu, will the psu and cooling be ample?
