Need help with PC watercooling
fluffyhamster
Hi does anyone have any referral for watercooling sli setup pc that is not chop carrot one? Thanks appreciate!
singupingu
Define chop carrot? Carousell got some custom builder specializes on watercooling you can take a look though
If you want warranty with it, pay for Aftershock or Typhoon System. Won't be cheap, but it has warranty.
Sent from Finally Unbanned using GAGT
watzup_ken
Water cooling as compared to air cooling is not cheap. Also, there runs the risk of leakage and pump/ fan failure. With all these in consideration, I won't recommend going for water cooling.
fluffyhamster
I am looking to watercool my 980 ti sli, top card under load over 90c...
My Cpu is using H100i closed loop.
Is there many people selling their service over at carousell? aftershock these company dont do existing setup right?
Unless anyone can suggest any methods to bring down temp for my 980ti. i also dont feel like watercool but that seems like only option for the card that hits 90c
lifeishard
So you just need to bring down temp of one gpu. How about looking at nzxt g10 kraken.
kyle8151998
Do you plant to do a loop for gpu only or loop for cpu and gpu?
If you want I can offer you my service, to do a custom water cooling loop.
But this may take time as we need to know what you want and then order the parts. If you are interested we can discuss just send me a PM.
shadow84
I wun recommend coz i used it before. While you are able to cool the core, the VRMs wun be cooled effectively. I tried on my 290 and while the core shows 6x degC, my VRM shows 100 degC during gaming.
A cheaper alternative is to get the EK bundle with cpu and gpu cooling. You can add another gpu block if wanna cool both cards, along with additional fittings and tubing.
https://www.ekfluidgaming.com/ek-kit-a240g
