Need help with pc
RocketBunny
Need new
Mobo
GPU
CPU
PSU
Network card
Ram
Budget probably round 600? Now qoo10 has coupons and discounts so hoping to get from qoo10 if it's cheaper.
Wanna get the Cooler Master N200 casing
I have my HDD and SSD which can be brought over.
Mostly for Gaming and watching videos.
Games like CSGO, Killing floor. Fps games.
Tia
ZrE0_Cha0s
but the games u playing is also like COD and BF as well?
next what's the monitor u going to use? intend to upgrade higher than the current?
lastly might be quite tight for 600 budget (even with discount)
RocketBunny
MianBaoFren
Budget can adjust ba. See how much. Don't need latest
Oh cause I'm using n200 for another PC so tot going for the same :(
Adjust everything to the most budget for your initial quote first. Then after that slowly tweak your components. That's what I will recommend.
I remember last time moneyface recommend a casing with a 300w psu for someone. It's itx though if I remember correctly. Still it's enough for a gtx1060
Sent from A Cat Who Does Not Need A Reason To Post using GAGT
RocketBunny
ZrE0_Cha0s
