need help with remaining parts
gerrickchua
hi all,
need some recommendation on the most value for $ for the rest of my remaining parts, don't really have a budget but just wanna spend as little as possible, maybe $500 to work with?
usage is just to play overwatch & LoL, the rest casual, very simple usage
currently have gtx960, ssd with me
what i had in mind was: h110m+ g4560 or should i get i3-7100?
so i'll need mobo+processor, psu+casing, prefer matx/itx but not sure my gfx can fit or not? im using this version: http://www.palit.com/palit/vgapro.php?id=2442&lang=en&pn=NE5X960S1041-2061F&tab=sp
and ram i can probably source for a 2nd hand one online
thanks all
dgenex
Definitely G4560 over i3-7100.
PSU budget one can get FSP Hexa+, but suggest you get a good PSU like EVGA G Series.
Casing Tecware F3 is the most budget, pretty decent, just kinda tight for cable management. More quality options would be Fractal Design Define Mini C, Phanteks P400TG.
gerrickchua
i think g4560 would be better value for money, almost 2x the price for a mere 10% increase not that significant to me. i'll go with h110m too the standard mobo.
is there a huge diff between diff ratings of psu or just brand reliability?
singupingu
Yes. Difference between rating of psu is significant. 80+ Gold psu have better components used and better power savings. Most of them run more quiet with the 0-rpm Eco mode when the psu is at low load. Cleaner power output also helps preserve motherboard components lifespan too.
However, if your usage is very low power, a normal 80+ is suffice instead of needing 80+ Gold (even though it's good to have). Usually, for low power usage or budget build, I would just recommend a normal 80+ or 80+ Bronze. Only when overclocking is involved, I would highly recommend 80+ Gold psu.
Sent from PM me if you wanna build a DIY PC or wanna learn how to make one yourself :D using GAGT
Irenicus
hi all,
thanks all
Hi, these are my recommendations based on your budget and requirements (assuming that you are buying RAM 2nd hand and reusing your HDD/SSD & GPU).
All prices from Tradepac:
Option 1:
CPU & MB Bundle: AMD Ryzen R5 1600 & Asrock AB350M @ $411
Casing & PSU Bundle: Tecware F3 & FSP Hexa+ 450W @ $80
Total Cost : $491
Option 2:
CPU & MB Bundle: Intel i5-7600 & Asus H110M-A M.2 @ $405
Total Cost : $485
gerrickchua
Noted very informative thanks, so for my context I'll only need a 80+ normal/bronze since not intending to do any over clocking. Just casual gaming and usage
gerrickchua
Bro can ask why 7600 over g4560? I checked h110m + g4560 at $203 and I intend to use the rest of my remaining Budget to get a monitor if possible current one quite cui haha
Option 1:
Total Cost : $491
Option 2:
Total Cost : $485
orlengtao
If you are playing games like overwatch and LOL, g4560 is more than enough. i5 7600 or ryzen 1600 is overkill.
Take the savings to get a better PSU / SSD / GPU / Monitor.
dgenex
Its a better CPU from a higher price range. But for your current usage seems the G4560 will be sufficient imo.
Though if you have the budget, Ryzen is a good upgrade.
Anyway monitor can get Dell SE2417HG if you want low response time TN panel, S2316H if you want IPS display. Good monitors for under $200.
Irenicus
Because you did not mention that you needed a monitor as well, so I used your budget on a better CPU.
i5-7600 has 4 cores & 4 threads VS G4560 with 2 cores & 4 threads. FYI, Ryzen r5-1600 has 6 cores & 12 threads. More cores and threads are better as current and future games will take advantage of it, as well as game streaming, video editing/encoding, etc...
gerrickchua
Hi guys, for the h110m, does it only support ddr4 or both ddr3 and ddr4? Would it be a problem if I were to use ddr3 ram sticks instead?
singupingu
gerrickchua
