Need help with some GPU problems
Tsunayoshii
so i have some problem with my gpu
1) my gpu seem to be quite bent/slanted. i am scared that it will damage my gpu.
imgur.com/a/9MlnL
2) my gpu cant seem to go over 1114 mhz core clock no matter what i do and even if i play long hours of cs/dota2 (i am new to msi afterburner)
imgur.com/a/odldE
lastly, i mostly play csgo and my fps is not as high as i expect it to be it seem to be around 140-170 on all low and i have msi gtx970 gaming 4 twin froze v
and my last com is have a weak gpu like gt 660 and it run around 100 - 120 fps..
thanks for your help in advance :)
Phen8210
imgur.com/a/9MlnL
imgur.com/a/odldE
Show us your full pc specs.
And clean uninstall ur driver using GURU3D Display Driver Uninstaller, clean up all your past amd/nvidia drivers..
Then reinstall the appropriate driver for your 970.
Tsunayoshii
My full spec is Msi z97 gaming 5 mother board
Msi gtx 970 twin froze edition
G.skill 16gb ram
Silicon power 256gb ssd
W.D black hdd 1tb
Intel i5-4690
Fractal design r5
And what do you mean by clean up past nivida driver and how do I do that?
