Need help with sound driver
zenitro
As title said, I need help with sound driver
Using the onboard audio on mobo[B75m-DGS](no sound card)
At first I plug in my headphone and there is sound coming out of both my monitor speaker(plug to back panel) and my headset(plug in front panel). After checking playback device I found out only the speaker was on the list. The headset wasnt detected at all
So I decided to update driver. After I updated driver(realtek) the problem still persist
Anyone know how to set headset as the default audio and if headset isnt available then speaker should start automatically?
yusoffb01
even without the updated driver, once u plug in front panel audio, the output to speakers will be disabled automatically. if not, click on volune icon, click on drop down menu for playback device, then click headphones. if not detcted, check hd audio wire if connected properly instead of ac97
zenitro
ya i plug in my headset to the front panel and i can heard from both speaker and headset at the same time. When i check playback device only speaker is listed. When i disable speaker, both speaker and headset have no sound. So headset wasnt detected at all
HD audio wire is the one from casing to motherboard right?
havetobuy
in the realtek windows..on the top right hand middle screen is a small icon
click it
its will says
disable front speaker detection(or sumthin liked that)
ticked it
sound shud come out from front lioa
