Need help with this
acidcrash
Been out of touch for a while. Read up a bit and just to clarify.
The B+M key is compatible with the board? 2nd from left last picture? Thanks
NightRaven49
only if it is an nvme drive, the spec sheet doesnt list support for sata b+m key ssds on the m2 slot. if the drive u want to add is indeed the 2nd from the left (nvme) then it should work.
acidcrash
Messaged the seller and replied untested but can try and see and also said it supports nvme.
Phen8210
Both m key and b+m key ssd can fit into an m key slot, your concern only lies with whether it's nvme or sata, in this scenario it supports nvme.
seller probably laughing behind the screen I think
