Hey guys, bought a 2nd hand pc from blue zone a few mths back but didn't had time till now to find a solution. So basically the seller lied to me that he install the full windows 7 but it was a trial version which has expired a week after I bought from him. I had lots of problem after it expired and got infected with virus and I recently opened the case to check then I found out that some parts were not installed properly(loose CPU cooler, loose ssd which was just placed on top of motherboard). My fault for not checking in the first place
Since i know nothing much about computer stuff so would like to know if there is any trustable shop I can go or person to contact to help me install new os, reset everything and install the components properly? Thanks a lot
