NEED HELP!
s0lidus1980
My girlfriend passed away and her contacts are in the phone. Unable to contact all the friends and relatives and colleagues.
How can I unlock? its not rooted, registered to samsung mobile, stucked at locked screen (password)
Called samsung they only say reset and lose everything.
Need Help!
cscs3
Need Help!
It should be private and confidential I guess.
s0lidus1980
Its samsung Note 4 with screen lock password lock ( not pattern )
I have googled many methods and found that the phone
Has no samsung my mobile setup b4,
Not sync with google account,
No usb debugging switched on,
Not rooted,
No Micro Sd card,
Any experts please advise (urgent)
lxb_70
Not rooted,
No Micro Sd card,
Am sad to hear that, my condolence..
if did not sync with google account... there is nothing that you can do... which means the contacts are in the phone itself.. don't think can be retrived. imo
or by any chance that the contacts are in the sim card?
tkl23786
lenseview
Note 4 will be a hard nut to crack. If Knox active protection is switched on, you will not be able to root it also.
If you are able to root it, using file manager in recovery mode, you can delete the files containing lock password/swipe pattern. Hence removing the lock on the device.
s0lidus1980
Really appreciated the help.
I just tried kies and kies 3.
Old kies doesn't detect the device.
New kies 3 does detect device but in kies it asks for password to unlock.
T__T:(
tkl23786
It is a headache if the phone is not connected to Google account or Samsung account.
All the unlocking solution involves Google account or Samsung account to sign-in to the unlock phone function...without the accounts, it will be difficult.
We need experts who might know how to do this...
Have you tried using social media?
Contact mutual friends and inform them about it.
Let them inform more people about it.
s0lidus1980
tried asking but none have a solution.
The Android device manager can ring, locate, lock and erase device. ( able to login gmail PC )
I tried lock and end up it does not overwrite previous lock screen password.
thats the closes i could get. Even tried odin3 custom recovery but odin failed and restarted by itself. ( not sure whether need root anot but I do not have usb debugging or adb switched on!)
lenseview
Read up chainfire and drkretan way of rooting note 4. If that fails, most likely Knox active protection is on. Then theres no way to root the phone.
Edit: read up at xda forum.
