Need help
evq
Pc won't post.
Just upgraded my mobo, cpu and ram. Setup last Tues, working fine, just that it will stuck at windows loading screen for like 5min before loading into Windows 10. So I off it and took removed 2 ram sticks and left only the other 2 to test. Now it won't even post
Pressing the start button;
- no display
- fans connected to mobo and corsair h110i working
- got light in mobo
- press reset button, won't reset, have to hold start button to off it
Any bro here have any idea what might be the case? Mobo dead?
jtjt00
Your SSD is in raid 0 mode. You fresh install OS or use previous installation OS?
evq
Already did. Anyway later I will try minimum bare setup and see. If still cannot post, 1ill have to send it down to Sim Lim for diagnose.
