Need help!
jtjt00
TS, best if you can list down the parts of your like those on the right - - >
inversedark
now managed to start up my pc... dont have spare gpu to test. i was playing ds3 when suddenly my pc auto shutdown
inversedark
can someone advice on how i can upgrade for my pc? i think same thing might happen again
jtjt00
Auto-shutdown maybe due to over temperature. Do check both your CPU and GPU temperature.
inversedark
for now i managed to boot up and use my pc but i don't dare to play any games. is there any gpu recommended for upgrading?
Wataru
i think $600 sgd MAX
Prices for brand-new GPUs are crazy mad-ass stupid right now. $600 will get you a GTX 1060 6GB at best now.
One alternative is to look for a 2nd-hand GTX 970 on carousell and squeeze to below $300. Performs faster than ur R9 280x, and chances are most of them still under warranty.
DIE DIE ask for receipt
tmfwy
Hi guys my pc suddenly crashed and displayed 2 red light when I try to restart my pc https://imgur.com/a/T9ZQe I am suspecting it's my gpu that's faulty need advice please!
If budget is $600, easy to get single card GTX10606gb
Prices to go is about $500 but i know many are hoarding up for CNY.
So if you are willing to part with $600, just buy it asap
Small increase coming. Bigger increase in CNY
If you want the card at RRP, besty to consider upgrading the entire system. :)
inversedark
Guys before I go buy new gpu, can i check will my current parts be compatible with the 1060? And is it easy to replace the gpu by myself?
Koenig168
GPUs use the same PCIe interface so yes, your existing parts will be compatible.
Replacing a GPU is straight forward. Do remember that there is a small latch at the right of the motherboard PCIe slot that you will need to unlock to remove the existing GPU.
