Need help
gerker2009
I just build my first diy pc and flund out there is a led light on the dram led... So i tried to take out 1 ddr4 ram and it works... Both ram i tried placing at 1 slot works... it only dont work when i tried to do dual channel... anyway i cn fix dis???
yusoffb01
if within the week u call the shop to see if they can test. then bring the motherboard to the shop
gerker2009
I boughg it on the 7th feb from tradepac... Not sure if i cn get a 1-1 echange from dem... will try to check on monday but not feeling hopeful that dey will help... sigh... currently my 2 x 4gb ram is installed in slot a1 and a2
LLCSG12
Go to distro..
pls.. again ppl.. pl just just do Not do what a few people say in this forum.. TP does not take any products from distro and where the cash goes is .. sigh.. censored
tmfwy
enjoy the TP experience
If ram has distro sticker, go to distro.
If not, go back to place of purchase. ha ha ha
What mobo
Some mobos is 2nd and 4th slot. Eg: MSI
If you put 1 and 3 slot, it will flash big red error...
gerker2009
Asus strix b250f gaming... so distributed is ban leong???
What mobo
Blindaim
The motherboard manual recommend use slot A2/B2 for dual channel.
ZrE0_Cha0s
Made a check and confirm its from avertek... will have to go down n see how... do i need to bring anything else other then da motherboard???
Well best to carry your whole PC for them to diagnose with the parts u have. If you can't den maybe I should at least wrap the board with statics bag and put it inside a box where it's at least could protect the components.
gerker2009
Ok noted thanks for the advice... avertek opens on tues, will go down n check wif dem
