Need help!!
overlord4101
Hello guys! My pc will suddenly turn off, but the power is still on and my motherboard will show have the CPU fail led light up.
I recently changed my GPU from 1060 to 4080 and my cpu fan to Noactua NH d15 and also upgraded my PSU to NZXT 1200w.
While changing my cpu cooler I did not remove the cpu but I just left it there. It was working well before the change
after the change, I will be able to boot up, but around maybe 5-10 minutes in, the monitor will just go black but everything else in my case is still running. Then my motherboard will show the led that indicates CPU fail.
Temp wise I’ve checked, my Noctua max 70deg under load(for that 5mins) before it just shuts off.
does this mean it’s a major cpu failure and I have to buy a new cpu?
86technie
Which motherboard are you using?
FYI RTX4000 series may not work in older motherboard, unless there is BIOS update.
I hope it is not 6/7th gen motherboard as to my knowledge RTX 4000 won't work.
Rogue
Go to bios, and reset to factory default settings, update bios if there's any. Then try and see how long it last. If it lasts, tweak the bios settings up.
If not last, look at every power plugs and see if they are correct (not sure if your PSU have labelling on it) and seated properly. Remove 4080 and try again with 1060.
overlord4101
It managed to boot up this morning, I did the reset and then updated the bios. Checked all the power plugs all correct, 4080 is using the single 12vhpwr cable.
only lasted like 10minutes before the same thing happened.
just wondering if my mobo is giving the led that shows cpu failure would the gpu be the cause of it?
jim889
did chiu scrape / wipe off the existing thermal paste and put new on one when changing cpu cooler?
:unsure:
overlord4101
Yes I did :(. Temp is not an issue as I did some heavy load (temp never go beyond 67 deg) before it shut off
jim889
mother board have built in beedio?
maybe can try remove beedio card and try to reboot see how..
:unsure:
Land2005
Did you check if the CPU got slight dislodge upon remove the old cpu cooler as sometime CPU will stick to thermal paste. It's better to take out CPU check for any pin bent and install whole thing again.
86technie
Is very hard to say, if you brought from a shop suggest bring the parts like PSU, graphic card let them test.
For me I suspect could be PSU, NZXT PSU are rarely used.
If you bring to the shop and the PSU is the fault I suggest change to MSI PCIE5 PSU.
Sadly in current market very few PCIE5 PSU, I hope the parts you did not buy from Carousell.
If from Carousell it would be even difficult to return and do a exchange.
Yongkit
Try monitor your power usage using HWinfo during the stress test and check the 12v rail power in HWinfo does it go below 12v
jkohlc2
some stuff you can try
replace motherboard cmos battery
use only 1 stick of ram and put in different slots and stress test
borrow different psu
Yongkit
Also check windows WHEA report to see possible reason of crash, assuming you do not oc or set any manual pbo or Co settings
peterchan75
Since you upgrade from 1060 to 4080, did you uninstall the driver? If no and all else fail, then try using display driver uninstaller(DDU) and reinstall the Nvidia driver.
kimsix
try to carefully unmount heatsink, take out cpu and put back cpu and mount back heatsink, to rule out mechanical accident loosen the contact in your first try
am4 always got chance cpu stuck on thermal paste on hs. :o
