It used to be that if, say, you mixed a HD5870 with a HD5850, then the HD5870 drops to a HD5850 in performance so that effectively, you'd have 2x HD5850 in CF. Now, I can't say for sure, but it's been said that mixing a HD7970 + HD7950 would yield a performance between 2x HD7970 and 2x HD7950. In other words, it'd be better than two HD7950 in CF, but not up to two HD7970 in CF.....at least, that's what I'd heard.will it be possible if i use a better gpu like 7970 will the performance drop or increase?
Any links where I can read up on crossfire?
Question, once I've 2 cards (same model) installed to run crossfire, it is possible to configure the such that only the primary card is running while the secondary one is off by default (meaning no power is consume)? When I start up 3D intensive games, the secondary will on automatically and run in crossfire mode to improve performance.
The secondary card will idle itself automatically for 7000 series, other series I not sure
