Need Recommendation for B&W PC build!
arhjaye
Hi! I need a recommendation for a black and white theme build with a budget of 1.6k inclusive of monitor and OS. Have got a Samsung evo 250gb SSD already.
Will be using it for Photoshop, premiere pro and after effects and would like to play 1080p games decently on it as well, no need for super high fps.
Many thanks in advance!
MoneyFace =p
CPU+MB: Intel Core i5-4460 + ASRock B85M Pro4 @ $327
RAM: Kingston HyperX Fury DDR3-1600 CL10 16GB Dual Channel Kit [White] @ $195
GPU: ASUS GTX 970 4GB Turbo OC @ $488
HDD: Western Digital Purple 3TB @ $161
PSU: Super Flower Leadex Silver 550W [80 Plus Silver] @ $109
CASE: Corsair Carbide SPEC-03 [White] @ $84
OS: Microsoft Windows 8.1 Pro 64-bit Product Key [OEM] @ $35 (G2A)
Currently OOS.
Download ISO here.
And upgrade to Window 10 Pro for free thereafter. Save yourself $100.
DSP: Dell S2316H 23" 1080p 60Hz W-LED [AH-IPS] @ $209
Total: $1608
Buy thers from Tradepac, #05-18. Haggle for discounts!
arhjaye
Currently OOS.
Download ISO here.
Total: $1608
Thank you! If in future I wanna add another SSD or HDD, can I remain the same PSU? and for the OS, anywhere else I can get it cheap? Will be getting the build next week and g2a seems to be out of stock for quite awhile already.
MoneyFace =p
PSU can maintain at 550W.
OS can get for free if you love trekking mountains like me..... :D
arhjaye
Yep those PRODUCT are the KEY things in order for you to achieve the recognition CERTIFICATE for trekking to the summit. :s13:
So if I bring SEVEN dollars to the summit, I am still eligible for the TEN FREEbies? LOL (many thanks :D)
MoneyFace =p
Surely, look at all the goodies i have there >>> :s13:
arhjaye
Currently OOS.
Download ISO here.
Total: $1608
Any idea how much discount they normally give? Trying to squeeze in alittle more budget to get a i7 4790 for my editing needs
MoneyFace =p
I did managed before about $10 less than overall listed price.
Core i7 will cost $150 more, but what sorts of editing are you doing?
arhjaye
$10 less for each item? Or just $10 off total price?
I'm not sure exactly but planning to self learn after effects with this new com. Read that editing and rendering is quite cpu dependent so was thinking to get i7.
MoneyFace =p
$10 less total la. If able to get $10 off each item i think i should also run for election next time with that convincing capability. :s13:
arhjaye
Went down yesterday to get my build! End up after paying they told me no stock for mobo and offered me gigabyte b85 d3h for a small top up, Lanlan just took it. Is it a good mobo?
Total paid $880 for everything without monitor & gfx card (getting from lazada) and casing is fractal r5 window. Got kena chop carrot anot? :p
mib500
what other items you get from them other than mobo?
