Need Recommendation for Gaming Parts
intrance
Hi guys,
My PC below was built in late 2015 with help from this community, and just last year, I change my graphic card, casing, PSU and add in another 8gb Ram. Great with the games I play.
But now I also intend to play and download the new Battlefield 5, but looking at the game requirement, unfortunately, my processor cannot make a cut.
Please help to recommend me a good motherboard, CPU and RAM. If there is a need to change any other parts, please suggest them too. Anyhow, I do not want to spend much money on them.
Many thanks in advance.
Processor
intel i5-4460
Mainboard
asrock h81m hds r2.0
Graphics Card
palit gtx 1060 3gb dual fan
Memory
kingston value ram 16gb 1600mhz
Display
philips 23" 234e5 ips
Storage
samsung 850 evo 250gb /zotac T400 120gb / wd blue 1tb
Optical Storage
samsung ultra thin dvd writer - external
Casing
Tecware Nexus M TG
PSU
EVGA GD 550W [80 Plus Gold]
OS
windows 10
shadey
For selective parts, look at all the "recommend me a rig" threads and adjust from there.
What is your budget anyway? Your GPU will be the biggest upgrade
Taunee
keep your storage, PSU, casing and GPU (Better to upgrade). The rest need to change.
hellspawn_one
Start by changing your gpu first. Then your cpu and mobo second.
You are most likely bottleneck by the gpu.
Sent from Samsung SM-G970F using GAGT
Koenig168
BF5 is CPU-intensive. The GPU could do with an upgrade as well.
So at a minimum, CPU+MB+RAM+GPU.
intrance
thanks bros.. for the suggestion..
at this moment.. im getting CPU+MB+Ram first..
All depends on your budget. You don't tell us your budget, how to recommend??
paiseh...:s34:
no budget but as cheapest as possible... :o
dont mind playing in low FPS cap.
maybe year end bonus, can have budget to overhaul all... :D
