Need recommendation for MB
wuming79
Hi Guys,
I'm looking for a replacement for my Gigabyte H77M-D3H MB. I think it died. Power on, fan turn a bit then stopped completely without even a single beep. Tried short test on my Seasonic 520W PSU and it is still running. I guess I can reuse right?
Any recommended MB that supports Micro ATX form factor with dual memory slots?
PC often used for adobe photoshop graphics design. I'm using integrate graphics from H77M-D3H. My CPU is Intel i5 3570.
localITguy
Suspended
Hi Guys,
Gigabyte motherboards are known to have Self corruption BIOS issue, try to recover to ur secondary BIOS
https://www.overclockers.com/forums...-Forcing-backup-BIOS-on-Gigabyte-motherboards
if canno't means ur MB is dead.
buy a replacement board from lazada,aliexpress,carosuell (50-70 SGD)
wuming79
localITguy
Suspended
I totally cannot boot. Can't even go pass Post. Yku mean buy back the same motherboard?
when a BIOS is corrupted it will not POST
Please go and try the steps in the link I provided.
try replacing the CMOS battery also.
if cannot, go buy a LGA1155 Board online ( cheaper)
hwarzoner
Yes try replace CMOS battery first. My asrock MB replace CMOS batt can power up.
wuming79
Hi, my mb confirm dead. Any recommendation for mb? If OK, I can change cpu also.
wuming79
I have also replace with a new cmos. Fan move a little when I power up, then it stop without any beep. Followed the guide above to enter backup bios also did not work.
wuming79
https://shopee.sg/Gigabyte-GA-H77-D...3.0-H77-DS3H-H77-board-i.165225318.7809995626
Or u can search on carosuell for a used H77 Board. or go SLS and look for old stocks ( more epensive)
try to get a board with the same chipset (H77 in your case) to reduce having issues
or u can buy a new cpu+mbo+ram combo ( ryzen) (
Actually I'm thinking of second option also. Just not sure what to buy with my usage. I don't play game v with this machine. Purely watch YouTube, do Adobe design.
What issue could happen if I change to be models?
localITguy
Suspended
if you stick to the same chipset, it's gonna work right out of the box
if you use a different chipset. say a H61 instead of a H77. Your OS *Might* not boot. and u might need to re-install the drivers however, windows 10 is very smart at detecting hardware. so i don't think that its gonna be an issue
Or just get a whole new AMD Combo bah. I think your board-lasted very long already
wuming79
Yah, I'm ready to install new os. Just looking for a model to go grab. :)
dreamaurora
If you want to the Ryzen route, cheapest would be to get Ryzen 3 3200G with any A320M MB. Local bundle price around $250, although you can get slightly cheaper if you buy from Amazon. You will also need to buy new set of RAM around, 16 GB around $80-100.
wuming79
Any recommended brand for R3 3200G? I'm looking at the fuwell price list. Asus, MSI and Gigabyte, any comments on the reliability now?
Those with WiFi behind ok to buy?
localITguy
Suspended
Not Assrock.
any brand would work. A320 is a budget chipset, just get the cheapest
