Need recommendation for motherboard...
LordStark
Hi currently i wanted to buy myself a new motherboard as i using quite old CPU and motherboard ( AsusTek P8H67M-LE and i5 2400 sandy bridge)
Any recommendation for motherboard for me?
MY current specs is....
GIGABYTE GTX 770
PSU 750 watt
Samsung EVO SSD
4TB WD Black
H80I CPU cooler
Budget around 400-600....
Please give me reason why i should take those motherboard...
Thanks alot..
MoneyFace =p
Thanks alot..
Your CPU is not old at all..... Still very fast considering Haswell is not much faster, just mild evolution ahead....
LordStark
yea...but i planning to purchase a new MB, so might as well go for a 4670k cpu too lol
thegamer1907
i5 2400 is still considered fast by today standard. upgrading to a haswell i5 would not make much difference. suggest you invest in something else or wait for broadwell and see if there is any significant improvement in performance
MevolutionX
Can just use your old motherboard and CPU. 2400 is fast enough. Haswell is like only 10% faster. Not worth it imo
LordStark
wow thanks bros....how about i just change my motherboard? will it be not recommend too?
thegamer1907
not reccomended, because the 2400 isnt compatible with the newer motherboards due to the different socket. so it's etheir you change both cpu and mobo or wait.
another option is to hunt in 2nd hand market
whats the reason u want to change the motherboard?
Assault
this guy is trying to say... 'I JUST WANT TO SPEND MONEY'... you guys keep stopping him lol
LordStark
i didnt say i wanna spend money,that why i ask for recommend...if not i wont buy....i buying cause i dont know if i need a upgrade now or what...2nd my front panel usb socket seems spoiled ( on motherboard USB)... lol dont seems it working...i plug in my h80i socket and there dont have power LED =(
LordStark
ok sir...thanks, now i understand my cpu still good xD
