Need recommendation for pc repair store
icyblu3r
Not sure what's the problem with my CPU, but here's my problem.
my PC shuts down automatically and it fails to power up, however my GPU fan(still running), processor fan (is running), power supply fan(running) no other LEDs, no signal nothing.
I have also tested my ram piece by piece but to no avail. everything seems to be running, but there's no light on my CPU
what will be the cause... how can i handle this prob..?
Need some recommendation of repair stores around simlim. Thanks a lot!
Oh right, here are my spec.
Processor
AMD ANTHLON 7750
Mainboard
ASUS M2N68-AM PLUS
Graphics Card
HIS HD 4850 IceQ 4 Turbo 512MB (256bit) GDDR3 PCIe
Memory
Kingston 2gb DDR2 X 2
HDD
Hitachi deskstar SATA 500GB
PSU
Andyson G530
Currently running on window vista. Just need recommendation on PC repair stores around SIMLIM.
THANKS!
jtjt00
You should list down all parts of your desktop like mine on the right ->
Maeda_Toshiie
Personal initial assessment:
1. Mobo playing up
2. PSU playing up (if you can get hold of a multimeter, check the voltages via a molex power connector)
BTW, is your CPU fan choking in dust?
PS: your system is really old.
localITguy
Suspended
Go to gs's shop (username gs in HWZ) (Nigel) #02-32 @ SLS ask him for help.
icyblu3r
Yea my system is old but still able to support the games I want to play in Max setting(dota 2, l4d2). Thanks guys. Hopefully I'm able to repair instead of getting a new one.
ForThePride
I had similar problems awhile back. After researching it was either motherboard some voltage regulation circuit acting up. If you overclocked before it could be not enough voltage getting to the cpu.
2nd option could be PSU problem.
icyblu3r
Yea guess I would change my mb and processor. Is it possible that I could still reuse my graphic card?say if I change to msi-b85-g43 and an i3-4130?
My casing is Power Logic Futura 250. Not sure if this mb can fit in the case.
And please advice if there's any part I could reuse if I change to this mb and processor.
Thanks!
FIREBOWS
Thanks!
You need to change your ram to DDR3 and your old hard disk seem like a IDE one, new motherboard mostly using SATA already.
For your case, it might be more practical to overhaul the entire system.
Can consider Ive bridge setup if on budget, also use the onboard graphic if don't do heavy gaming.
icyblu3r
Thank you everyone for taking your time to reply.
Will go to Nigel as recommended. Thanks a lot once again!
icyblu3r
Oh ya one last question. For what you recommended for ivy bridge, ASRock b75m-DGS + i3 3220 good enough ?
localITguy
Suspended
yep. will work fine .
i3 still can play most games fine. if you looking into games like bf4, you will want to get an i5.
u play games? can upgrade GPU also.
addthewin
Processor
AMD ANTHLON 7750
Mainboard
ASUS M2N68-AM PLUS
Graphics Card
Memory
HDD
PSU
Andyson G530
THANKS!
most likely power supple problem.
icyblu3r
Yes definitely will give him some fee as I just read his recent post. Can't take advantage of a nice guy like him.
And really appreciate all you guys for helping me out here giving me advice.
Thank you so much for your help.
