Need recommendation for rig upgrade
ryoichi
Hi all,
This is my current rig setup:
Msi H97 Gaming 3 + i5-4460
MSI Radeon R9 290 4GB
Gskills Ripjaws 1600mhz 2x4gb kit
samsung evo 840 250GB SSD
WD Blue 1tb Storage Drive
Seasonic S12G 650W
Fractal design arc midi
Looking to upgrade the rig to support gaming and use of VMs.
Thus, would probably need to upgrade to 32GB of ram and another 2TB of storage disk.
What components will need to be replaced to support my needs? TIA!
sacredrays
would recommend changing to ryzen. means your mobo, cpu and ram need change. probably ryzen 3600, b450 mobo combo at the bare minimum?
gaming + vm concurrently? i think you need more ram and bigger ssd capacity (if your vm folder is stored locally)..
ryoichi
thanks for the reply. if im gaming, i will shutdown the VMs. Im intending to get 32GB of ram. What ram will be good? will be mobo cpu able to support 32gb ram? I intend to store the vm at my secondary storage with 2tb capacity. Do i need to upgrade my graphics card? Thanks!
budget is not an issue. Just want to get the best out of it to suit my needs.
ragnarok95
Senior Moderator
Senior Moderator
You can get Ryzen 5 3600 + B450 mobo. Or you can go Newegg and get a Ryzen 7 2700 + B450 mobo. 2700 for more cores over 3600.
If budget is not an issue then just get Ryzen 9 3900 with a X570 mobo. 32GB no issue. If you need more, can get 64GB memory.
chaoprokia
go aftershock get the spec u wan?
then paste here.
Then tell us what u wan to change.
Then we can recommend easier.
This way can tell how much Lui u have to customise LOL
NightRaven49
r9 290 is just enough for 1080p60 gaming today. really up to u if u wanna upgrade in preparation for 1440p gaming, or simply for power efficiency gains. anyway nowadays 570s, 580s and 1060s going for cheap also.
SkyShroud
As mentioned, go for Ryzen because you want to use VM thus cores/threads is a big factor for you. My budget recommendation is Ryzen 5 3600, less budget choice is Ryzen 7 3700.
For main board, budget will be Asrock B450M Pro4, less budget will be MSI B450 Tomahawk Max.
For ram, you can get 3200Mhz CL16 2*8gb. The brand don't really matter, just grab whatever cheapest you can source with that specification.
For gaming, seeing your monitor is 1080p, minimum recommendation is 1660 Super or you can also get 2nd hand 1070. 1440p recommendation is 5700xt or 2060 super, whatever cheaper.
Your SSD, PSU, Casing and HDD all can be reused.
TheCaffeEspresso
Ryzen 5 3600
Asrock B450m Pro or steel legend
Klevv bolt 8gb 3200mhz ram x2
Radeon RX 5700
Sent from HUAWEI Mate 20 Moonlight Blue using GAGT
chaoprokia
budget not issue must recommend monitor together. haha.
ryoichi
Thanks for the recommendation.
i will go for
Ryzen 5 3600
Asrock B450M Pro4
As for ram can i go for 3200Mhz CL16 4*8gb instead or 2*16gb?
As for graphics card how much difference in terms of performance between R9 290 vs 1660 Super? Worth to do the upgrade?
Also, i'm intending to change my monitor from 23" to 27". Is there any recommendation on which 27" monitor to get?
Is there anyone who can come my house who can help to do the upgrade of my rig? The rig is too heavy to bring down. TIA!
SkyShroud
i will go for
Ryzen 5 3600
Asrock B450M Pro4
2 rams vs 4 rams in a dual channel system
2 rams is slightly faster than 4 rams since less lane is used for more, not significant to the point of noticeable but is there.
2 rams will also provide less stress to the system, it also use less voltage, the system is overall more stable.
Therefore 2*8gb is always recommended.
You can check the youtube benchmark.
Monitor
When switching from 23" to 27". Normally is recommended to get 1440p for 27" because 1080p on 27" is really ugly with obvious blurry wordings. With that said, 1440p also require a different level of GPU for optimal gaming experience. You can shortlist the monitor here - https://www.displayninja.com/
chaoprokia
Monitor
got Ips 4k for 27 inch?
NightRaven49
if really want to upgrade to 1440p panel then must upgrade gpu le, but at least used 1070/tis are pretty cheap nowadays. can also look at used vegas, or if u r looking at brand new options, 5700/xt or 2060 super.
MrAwesomeX
Now nowadays I guess nobody use 1080p liao
Only me . Still sticking to gtx 1060 .
Nothing worth it now to upgrade.
Nivida nowdays keep rebranding it's cards with minimal improvement also .
All trying to buff consumers like intel already .
Devilsire
Monitor
TS mentioned use for VMs. Go for 2*16gb 3200mhz CL16 instead, is just ~$80 more from Amazon. WIth 32gb memory one can open multiple VM instances (4gb ea) and still multitask/tabs/video without any issue
MrAwesomeX
32gb go as cheap as 160 sgd during BF sales period.....:s12:
