need recommendation for self-build pc for FF14
troyden
Need recommendation for self-build pc for FF14.
i don't have monitor, need to have in-build wifi.
i'm looking at an affordable price. hopefully <2k
royfrosty
For FF14 the recommended gfx you would need according to them is a gtx660 that will work best for their game.
So for less than 2k. I would recommend you to get a gtx760.
MSI B85 g43 + i5-4570 ~ $356
Kingston Value Ram 8gb ~ $81
WD Blue 1tb ~ $81
Plextor m5s 128gb ~ $129
MSI GTX760 2gb Twin Frozr + Seasonic m12ii 620W ~ $499 bundle
Sharkoon T28 Red/Blue/Green ~ $87
Windows 7 Home Premium OEM 64bit ~ $115
Samsung ODD ~ $21 (optional)
TP Link 150Mbps Wireless N PCI Express Adapter TL ~ $40
LG IPS234 23inch IPS monitor ~ $228 (Best Price beside Fuwell)
Total $1637 Buy at Tradepac. DIY yourself. Monitor at Best Price shop.
If you want a cheaper alternative is you can get the Palit GTX760 2gb + FSP 550W Aurum Platinum bundle @ $399. That will sum up to $1537. Do take note that Palit is only 2 years warranty instead of 3 years.
troyden
thanks royfrosty. Just wonder what time does tradepac open and usually how long to assemble ?
royfrosty
Tradepac opens at 11.30am. Close at 8.30pm. Well it depends on the crowd. If it is less crowded. Within 1 hour you can get it. But take note. Stay in the shop and monitor them while they are doing it.
Felfirez
Get the cheapest GTX760 with the nearest service centre to your place.
Grimscythe
WD Blue 1tb ~ $81
Hi Bro royfrosty, Am looking to rig a gaming PC for the same purpose as well. However, I am looking at the i5-3570K instead, Could you kindly recommend a motherboard?. Budget is $200 for the Motherboard, as I plan to invest more on the GPU. Thanks, appreciate it bro
royfrosty
Not sure why do you insist on a 3570k ivy bridge? Any particular reasons? Even if we are talking about a higher end GPU an haswell 4670k is roughly about $80 more. Doesnt justify much to get a higher end GPU as the next tier would be cheapest 770 $585 vs the cheapest 760 $355.
Further more if you aint overclocking you need not a K processor. If you are you got to splurge on a cooler as well.
Grimscythe
Hi, Thanks for the quick reply, Yes, I am not going to overclock it as i am not a very tech-savvy person. Why i chose the ivy bridge is because I've read in various reviews and forums that for gaming, this processor is more than enough for today's games(Do correct me if I am wrong). So that is why I chose to not to go for any processors that are more expensive than this. I am generally new to this forum and field and I have no/little knowledge about building your own gaming rig. Any advice would be much appreciated. Thanks
royfrosty
Then i don't see why you need to get the ivy build with a K processor. A processor ending with a K is an unlocked processor. Allowing you to overclock it. And with that you will need any mobo that starts with a Z in front to do some overclocking. Furthermore it is slightly more expensive and also you need to invest on a good cooler. Which turns out way more expensive.
Since you are not a tech savvy person, just get a haswell cpu since your budget is quite generous. Cause a i5-4570 is just a few dollars away from the 3570k previous gen. Just get the 4570. Worth the money at just $20 away.
Unless you tell me that you are on a super tight budget, then yes you might need to go ivy and save that money for a gfx card option.
GTX760 is already good enough for most gaming needs at 1080p high to ultra settings.
Just get the B85 board and pair it with the non K processor and you will do just fine.
Grimscythe
Ok, Thanks for your time.
ragnarok95
Senior Moderator
Senior Moderator
Create another thread to ask for recommendation or PM him instead. Thanks. :)
deleted_nil
Sorry to hijack the the post a bit.
I would like to check what upgrade should i make to play FF14 without any disruption and hope to achieve score of 3500 and above :
Recommended System Requirements | FFXIV: A Realm Reborn Info (FF14, Final Fantasy XIV)
My current cpu :
OS : Windows 7 Home Premium 64-bit SP1
Cpu : Intel Core i5 650 @ 3.20GHz
Ram : 4.00GB Dual-Channel DDR3 @ 666MHz
Motherboard : Gigabyte Technology Co., Ltd. H55M-UD2H (Socket 1156)
Graphic : Generic Non-PnP Monitor on NVIDIA GeForce GT 640
HDD : Western Digital 1TB
Optical Drive : TSSTcorp CDDVDW SH-S223C ATA Device
Audio : Realtek High Definition Audio
Sound Cards
NVIDIA High Definition Audio
My friend recommend me to change :
intel core i7-3770 3.4GHZ
8GB ram
ASUS P8H77-V motherboard
PowerColor HD 7870 2GB or Palit GTX 660 OC (*Crucial as it require at least a GTX 660)
Any cpu tech guru can help me out on the above mentioned. I would like to change the above minimum but achieve the require score for smooth gaming.
ragnarok95
Senior Moderator
Senior Moderator
FF14...
Just get a 4570/4670 quad core and a 7870 enough...
shadow84
My current cpu :
Sound Cards
8GB ram
Got budget? No need for i7-3770. Get i5-4570 or i5-3470 will do. As for mobo, asus is premium brand with a premium price. Get msi b85m-g43+i5-4570 or msi b75ma-g43+i5-3470.
As for gpu, can try get 7870 myst. It uses the same chip as the 7950/7970 which is a higher tier but at a lower price with some offsets.
best is to create your own thread and ask. So as to not confuse others.
