Need recommendation on Mid-tower case
shortenigma
Hi guys,
I'm currently using a Sharkoon T28. I feel that the airflow for the T28 is not that great, and it feels flimsy to me too. Due to space constraint, my CPU is placed under the table. Hence I like to find a mid-tower case which can reduce the heat build up (even if a little bit) despite being under the table.
I'm currently looking at these options. Right now, I'm leaning towards the Arc Midi 2 because it has good airflow, air filters for all intake, removable hdd cage, and a simple design.
Hoping to hear your opinions :)
Fractal Design Arc Midi 2
332581a1-a177-4bd7-b6ee-29746564882b
Fractal Design R4
77283f52-3505-40db-8167-7d1149c876b4
NZXT 210
Corsair 500R
Skuyle
all of the above looks good, but im leaning towards fractal tho, m a fan of their cases.
sleek simple n gets the job done!
royfrosty
If you are looking for great cooling capabilities the 500r is one of the best out there.
In terms of good quality also.
But imo, if you can go 500R i dont see why you cant go 540 Air. Cause the width size difference is just 12cm away.
madeener
i actually got a mid tower from lian li to let go at cheap price if u can self collect...
shortenigma
thanks guys,
I like how the fractal design looks, but I will go look into the Corsair 540 before making a decision. And yea, I will definitely be adding more fans
xtwis7
thanks guys,
If your table/floor can have at least 30-35cm of width for allowance, get the Corsair 540.
souler87
thanks guys,
I like how easy it is to clean the dust filters at the front btm and top. Will be very good if you have a dusty room
