Need recommendations for CPU Cooler under $100!
exanthium
Hello guys :D
I need help/recommendations for a CPU Cooler under a $100 bucks.
Thanks alot guys! :s12:
Hua_Hui
from what I gathered - Coolermaster Hyper 212 evo
is the best cooler under $100
$64 I think.
E_G_G_S
what chipset are you currently using?
you must check first whether the cpu cooler you want will fit your cpu anot. also must check your casing fan clearance.
royfrosty
If your chassis can support can try Coolermaster V8. One of the beast out there lol.
V8GTS ~ $105 irrc.
Unless you want the V4 ~ $80
