need some advice/help on iphone
kenchi
i would need a msoffice or i know iphone ios got a equal similar appl similar to msoffice called PAGES and docu to go
may i know is it possible to have folder in that appls and example PAGES or docu ment togo and sync to comp and arrange it then sync to iphone?
what i need is like example on a blackberry or andriod i can have folder in phone and organize
thanks
maxheadroom
I guest you looking for a Microsoft way to sync to folder so you can edit from your computer.
For apple apps, they cut down to 1 step sync, why don't you edit in the iCloud direct since the doc is a the iCloud? Like google apps?
kenchi
what about if i use PAGES for IOS on iphone and create a folder and with a pages inside
so if i wanna sync to icloud of offline via itunes
will it reflected in my macbook in a folder or it in a lump of files?
if not any other alternative office appls for ios?
to recommend?
maxheadroom
Some how u still don't get it. Sync is no longer use in apple. If u open page on doc on iCloud on Mac or iPhone, iPad,, there isn't a sync. U directly editing it.
