Need some fan advice
Chevalier
I’m building a new rig , 8700k and I’ll OC to 5ghz.
Using my current ID cooling 240, the fan is really noisy.
So I’ll like to replace them as well as get new case fans, quietness is key, RGB is secondary.
What would you guys suggest for replacement radiator fans as well as case fans with quietness being key and still push decent air
singupingu
Gentle Typhoon AP15 with Phanteks Halos 120mm
Performance + RGB
Both for you covered
Sent from OnePlus ONEPLUS A3003 using GAGT
Chevalier
Performance + RGB
The GT AP 15 is high static pressure, best for radiators right? As case fans is it still suitable? Also,which shop carries em ah
Thanks for ur reco
dreamer_toons
Keen to know which local shop carry GT.
Placed an order for the GT at Lazada the other day but it was cancelled, cited OOS.
Some recommended Corsair ML but it doesn’t has the 80mm.
singupingu
Thanks for ur reco
The most balanced fan. Airflow is okay, static pressure is good too. No problem whatsoever. If you have a restricted intake (like NZXT S340 or Phanteks P300/P400), static pressure do a better job to bring air in.
I typically get them from Doraemon (t258jgn is his forum name) from Carousell.
https://carousell.com/t258jgn
You can try ask him see if he still have stock. He's a legit seller, quite well known here.
Chevalier
dreamer_toons
Thanks for the suggestion.
Hopefully he has the stocks.
pedokuma
royfrosty
I have 4 lightly used ek vardar F4 120ER custom length cables 30cm, 40cm, 2x15cm.
See if you need them. Any amount you think deem right i can pass to you.
Chevalier
about to pull the trigger on the Noctua NF-A12x25. this can do well as case fan too?
Ark Law
This so much.
Noctuas are good, but they don't undervolt as gracefully as GTs. Plus, undervolted GTs not only push MUCH more air than Noctuas, they are much more pleasant to ears as well.
Linus's love/hype for the NF-F12s are totally overrated. The only thing that could justify a Noctua purchase is the 6yr warranty and accessories that come with it.
royfrosty
Noctua is just too noisy lah. Doubt their new fan range are any better than just changing the blades.
GTs are the better options there over noctua.
watzup_ken
I personally like this, Fractal Design Venturi HP 12 PWM Fan. Quiet and yet I feel it cools pretty well.
