Need some help on upgrading my current rig!
tc4mez
I'm running an Asus P8H67M <Rev.3.0> on i7-2600 which I had hook up quite sometimes back on a very small casing. I intend to change to a bigger casing (Corsair 650D), add in a graphic card (Asus HD7770 2GB dual fan) & also add in a cpu cooler (Corsair H100i)...
Looking at the specs on my motherboard:
4 x USB 2.0 connector(s) support(s) additional 8 USB 2.0 port(s)
1 x IDE connector(s)
1 x TPM connector(s)
1 x COM port(s) connector(s)
2 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
1 x CPU Fan connector(s) (4 -pin)
1 x Chassis Fan connector(s) (3 -pin)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
1 x MemOK! button(s)
1 x Clear CMOS jumper(s)
It seems that I have only 1 x 3-pin chasis fan connector, what can I do to add a few more connectors for my fans?
Front intake fan - 1 x Chasiss Fan connector 3 pin
CPU Cooler - 1 x CPU Fan connector 4 pin
Rear fan to draw out the heat - ??? Please advise
I think I'm using one of them lower ends power supply, if I am to change to a better one, is there a possiblity to hook up a 3 pin connector for the rear fan?
I see that I have :
I'm running a SSD at the moment, I think I plug it into the 3Gb/s connector, should I change it to the 6Gb/s connector on the motherboard? Is there a big difference? I do also have a mechanical hard drive, should I plug it into the 6Gb/s as well or should I leave that for the CD-drive?
Any input is greatly appreciated.
Godeau
use a 3pin to molex connector to connect more fans
edit: link pic for chiu, looks like this
the molex connect to your psu
edit2: if u buying new fans sometimes they come with it and sometimes they don't so be sure to check
Godeau
2600 non-K ? i'm guessing you got this with the intent of not overclocking so there is no point getting a high end watercooling kit like the h100i.. but if you still want it just for the seh i'm not stopping you :o imo not worth the money spent, just get a decent air cooling will do
What was your previous graphic card?
yes. use the 6Gbps for ur ssd, personally the other drives like dvd rom etc I just put on the 3Gbps sata.
Upgrade Advice: Does Your Fast SSD Really Need SATA 6Gb/s? : Should You Feel Bad That Your Board Only Supports SATA 3Gb/s?
tc4mez
thank you for the information & the link to the writeup on the SSD, really appreciate it...
tc4mez
After messing around with my desktop for near 2 weeks, I replaced the graphic card, a cpu cooler, a casing & a power supply...
- Corsair Carbite 200R
- CM Hyper T4
- Sapphire 7790 2GB
- Corsair TX750i
I replaced the CPU cooler myself using help from YOUTUBE (cleaning off & applying the thermal paste), I realized that the CPU fan running at 600+ rpm only, is this normal at normal load with web browser & a YOUTUBE clip running. The CPU fan is connected to the motherboard 4 pin socket as per previous stock CPU fan socket.
I used the HWMONITOR to record these data. Is this a good program to monitor the data?
I found some old fans from storerooms, 2 x gigabyte stock fans, 2 x cooler master Excalibur, all 120mm fans, I intend to hook them up to my 200R (which already have 1 x intake in front & 1 x exhaust at the rear). I understand that the Excalibur are loud which was the reason why it was removed, can someone recommend me some fan controller for 5.25 Front Bay? I noticed that 2 of my fans are running 3 pin & the 2 Excalibur are 4 pin. Which shop in Sim Lim Square can I buy them molec connectors & what are thoses 4 pin or 3 pin male plugs for the fans call? Or is there a place where they can customized the wiring so I can hook them all up?
Should the fans be balance? I.E. 3 in 3 out or can I do 2 in 4 out? Any input is greatly appreciated. Thank you.
JustAnotherTroll
for more intake or more exhaust, go google on positive vs negative airflow. there's no exact correct or wrong to this question.
tc4mez
Wah just found a lot of positive & negative airflow from the internet, I'll do some reading before I go do up the fans!!!
Thank you!
