need some help or advise.
ltrinityl
Hi guys,
I have a iphone 7+ matt black and the rear of the phone has lots of scratches.
Anyone knows if theres any shop that can replace the rear only and maintain the waterproof of the phone?
Sorry for the bad english but hope you guys understands what i'm talking about.
Thank you
ragnarok95
Senior Moderator
Senior Moderator
Just buy a skin and paste over it, cost cheaper. Or simply just buy a ultra thin casing.
Snoweagle
Hi guys,
Thank you
In addition to the above comments, your best bet is doing it at the Apple Store as the rear housing is not just a piece like that. It has all the circuit boards, sensors, camera and battery assembly attached to it and doing it at a 3rd party shop is not going to be safe.
But do take note that it's going to cost you a bit.
delceer
Hi guys,
Thank you
don't anyhow go to ah beng shop repair.
go back to Apple shop to have peace of mind and good night sleep.
ragnarok95
Senior Moderator
Senior Moderator
if you want to repair iphone in singapore, there are only 3 places to go.
1) Apple Orchard.
2) A.lab.
3) QCD.
Other than these 3, no thanks.
ltrinityl
called apple and they say it takes $400-500 to change the rear... that's so expensive.. guess i have to go the wrap way...
thanks guys for the help and advices.
chenaz
Still under warranty ?
Bring back to Apple and fake something spoilt and get a refurbished set.
But bear in mind that. If ur scratches is very very bad . They will still reject to repair even if your device is still under warranty
chenaz
Taobao lor.
Anyway I bought one of this. Matt black(cos my phone is Matt) and I don’t use cover so I need something to protect the back also
Oh btw,
Any skins recommendation like brand or where to buy?
chenaz
Or this kind. Is really a skin. Just paste your phone. But need high level of pasting skills
ltrinityl
ok thanks all for the reply... think i now go find some wraps to play with
