need some help with assembling a pc
Jeremywong97
hi all, looking for a reliable shop that sells computer parts @ sim lim square
i've heard fuwell and pc themes are pretty reliable:s13:
also i was wondering if i would be able to build a pc at ard 1k at these specs.. i did my homework and from lazada, lowyat and a sim lim square flyer these parts cost nearly 1k, with very little variation
ASUS B85M-Gamer LGA 1150
i5-4690
ZOTAC GTX 750 TI 2GB DDR5
Corsair Vengance 2x4gb DDR3 1600
WD 1 TB Sata 3 7200rpm 64m cache
Seasonic M12II 520W 80Plus Bronze
im looking to be able to play some medium intensity games maybe like fifa 16 on high/ultra high and more intensive ones like GTA 5 at least smoothly on medium
appreciate all suggestions !!
ZrE0_Cha0s
not sure if gfx can play medium smooth, maybe can change to a better one if u can up ur budget abit more.
Jeremywong97
no bro no need keyboard / monitor / mouse i got that settled :s13::s13:
sorry but budget only around 1k...... :o:o
ZrE0_Cha0s
I see, well for ur mb maybe get those abit normal edition(non gaming kind) and ram change to valueram, den maybe enough budget for a better gfx.
herman1314
ok, here's what i can recommend you:
cpu and mobo:i5 4460 and h81m-hds $337
graphics card:sapphire r9 280x vapor-x(lazada)$274+3*
ram:kingston/g.skill ddr3 1600 8gb valueram $55
ssd:sandisk ssd plus 240gb(lazada)$82.90+3
hdd:toshiba 1tb $65
psu:fsp hexa+ 550w $68
case:corsair 100r $83
total:$970.90
*after lazada app mastercard monday 10% off($25 max)
all prices not bracketed are from pcthemes. do ask around for price quotes and discount before buying.
i5-4690
Too CHUI liao.
downgrade to i3 and get a GTX 960 instead.
ZrE0_Cha0s
Whats the diff btn gaming and non gaming mobo?
Sent from Sent from where? using GAGT
some extra better features, like what all manufacturer will say lol, but i would say have some performance gain and also other than that is like better stuff probably will be better ethernet controller, audio controller and HDD controller, etc. but in terms of normal usage its pretty much the same :o
